当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
The two halves should pull apart easily since there are no longer any screws holding it together.
The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
As mentioned in the previous step, there are wires still connecting the two halves.
Remove all the pieces of tape to detach the wires from both sides.
You want to gently peel the tape off, without pulling on the wires.
Spread apart your TV the rest of the way, but do not disconnect any of the wires.
You should have a clear view of the inside on both sides.
Using same screwdriver, unscrew the screws that are on the green display board.
Separate the green display board from its metal backing.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
