跳转到主内容
Inner Frame
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Inner Frame, Battery: 步骤 1 中的图像 1,1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Inner Frame: 步骤 2 中的图像 1,3 Inner Frame: 步骤 2 中的图像 2,3 Inner Frame: 步骤 2 中的图像 3,3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Inner Frame, Back Plate: 步骤 3 中的图像 1,3 Inner Frame, Back Plate: 步骤 3 中的图像 2,3 Inner Frame, Back Plate: 步骤 3 中的图像 3,3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Inner Frame, Hard Drive: 步骤 4 中的图像 1,2 Inner Frame, Hard Drive: 步骤 4 中的图像 2,2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Inner Frame: 步骤 5 中的图像 1,1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
  6. Inner Frame, Inner Frame: 步骤 6 中的图像 1,3 Inner Frame, Inner Frame: 步骤 6 中的图像 2,3 Inner Frame, Inner Frame: 步骤 6 中的图像 3,3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the six outside screws (7.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the seven inside screws (8.0 mm).
    • Using the JIS J1 Screwdriver Bit and Driver, remove the one inside screw (3.0 mm).
  7. Inner Frame: 步骤 7 中的图像 1,3 Inner Frame: 步骤 7 中的图像 2,3 Inner Frame: 步骤 7 中的图像 3,3
    • Using your hands, slide the brown release tabs for the keyboard connection away from the center of the device.
    • Gently remove the keyboard connection by pulling away from the center of the device.
    • Lift the black locks for the touchpad connections into the upward position.
    • Gently remove the touchpad connections by pulling the purple tabs away from the locks.
  8. Inner Frame: 步骤 8 中的图像 1,3 Inner Frame: 步骤 8 中的图像 2,3 Inner Frame: 步骤 8 中的图像 3,3
    • Flip the device over and open it.
    • Using the plastic opening tools, remove the cover/palm rest from the frame of the device.
结论
另外一个人完成了本指南。
Joe Kendall
于02/15/17注册
361 声望
创作了3篇指南
团队
USF Tampa, Team 8-3, Eyestone Spring 2017 USF Tampa, Team 8-3, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G3
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 97
