跳转到主内容
配件
没有特定配件。
  1. Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • Use a #0 Phillips head screwdriver to remove the four small black screws from the back of the device.
    • To ensure you don't lose any tiny parts during the replacement process, place parts on the white magnetic sheet.
    • Once the screws have been removed, proceed to take off back cover.
  2. Now, proceed to lift the battery out and remove it.
    • Now, proceed to lift the battery out and remove it.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing. Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
    • Use a #0 Phillips screwdriver to remove the four small silver screws from the outside corners of the battery housing.
  5. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover. Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
    • Now gently pry the front cover off. A Black Spudger can be used to assist in the removal of the cover.
  6. Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary. Pull the motherboard out and down away from the top of the phone.
    • Gently separate the mainboard from the battery housing. This may be difficult around the headphone jack. Use a spudger if necessary.
    • Pull the motherboard out and down away from the top of the phone.
结论
Lauren
于2014年02月13日注册
43 信誉积分
创作了2篇指南
团队
Ohio State, Team 1-4, Buehl Spring 2014 Ohio State, Team 1-4, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G4
3 名成员
创作了3篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 7
过去的30天: 9
总计 464
