跳转到主内容
加入维修社区 - 创建账户
Infinity v2 10.1 Camera Replacement
你所需要的
  1. Infinity v2 10.1 Camera Replacement, Back Case: 步骤 1 中的图像 1,3 Infinity v2 10.1 Camera Replacement, Back Case: 步骤 1 中的图像 2,3 Infinity v2 10.1 Camera Replacement, Back Case: 步骤 1 中的图像 3,3
    • Slightly pry open one corner of the device by using your finger nail to separate the screen from the back case.
    • Use an opening tool to carefully detach the back case from the tablet. Start by inserting the tool where your fingernail opened a gap, and work around all four sides of the device.
    • There will be a slight click noise as you free each tab.
    • Once the case is completely free, carefully lift it and place it face up on the workstation, being cautious not to damage the speaker wires connecting the two halves.
  2. Infinity v2 10.1 Camera Replacement: 步骤 2 中的图像 1,2 Infinity v2 10.1 Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the speakers from the case by gently lifting them up and out of their slots.
  3. Infinity v2 10.1 Camera Replacement, Camera: 步骤 3 中的图像 1,1
    • Use your thumb or opening tool to lift the black connector holding in the ribbon cable.
  4. Infinity v2 10.1 Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the camera by gently picking it up and pulling it free from the connector.
    • Avoid touching the lens of either camera.
结论
另外一个人完成了本指南。
sammytarbokas
于10/31/19注册
193 声望
创作了2篇指南
团队
UMass Dartmouth, Team S2-G4, Barthe Fall 2019 UMass Dartmouth, Team S2-G4, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S2G4
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 238
