跳转到主内容
Infinity Genesis Footrest Slide Assembly Replacement
你所需要的
  1. Infinity Genesis Footrest Slide Assembly Replacement, Remove Rear Panel of footrest: 步骤 1 中的图像 1,1
    • Both panels come off together. Do not try to remove them individually.
    • Remove all 11 screws to remove the panels.
  2. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 2 中的图像 1,1
    • Once the rear covers are removed you will be able to see the inside of the extend cabinet.
  3. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the 4 screws to release the extend cabinet from the front of the footrest
    • Remove the 4 screws to release the extend cabinet from the front of the calf massager
  4. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 4 中的图像 1,1
    • The extend cabinet should now be free of the front half of the footrest.
    • Remove the 5 screws to remove the front cover of the extend cabinet.
  5. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 5 中的图像 1,1
    • If the Feed Screw Nut needs to be replaced remove these 4 screws. They are held in by nuts that may need to be held when removing the screw
  6. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 6 中的图像 1,2 Infinity Genesis Footrest Slide Assembly Replacement: 步骤 6 中的图像 2,2
    • There are 4 screws holding the slides in place. To get access to each of them you would need to manually extend the footrest by spinning the motor.
    • Remove these 4 screws. Only 2 will be available at a time depending on how the slide it positioned.
  7. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 7 中的图像 1,1
    • The two halves of the extend cabinet will need to be separated at this point. Continue to spin the motor until the screw shaft is completely removed from the feed screw nut.
    • The two halves should be separated like this once done.
  8. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 8 中的图像 1,2 Infinity Genesis Footrest Slide Assembly Replacement: 步骤 8 中的图像 2,2
    • Remove the final 4 screws holding the slides in place.
  9. Infinity Genesis Footrest Slide Assembly Replacement: 步骤 9 中的图像 1,1
    • The new slides need to be installed onto this plate first.
    • The nuts attached to the new slides are for transport purposes only. They will not be installed into the footrest
    • The new slides CAN NOT be stood up on their ends once the screws are removed. The internal components may slide out and ruin the slide. All movement has to be done to the side.
结论
Mike Klessens
于06/26/18注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 93
