跳转到主内容
Infant Optics DXR-8 Speaker Replacement
你所需要的
  1. Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: 步骤 1 中的图像 1,3 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: 步骤 1 中的图像 2,3 Infant Optics DXR-8 Speaker Replacement, Internal Monitor Components: 步骤 1 中的图像 3,3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Speaker Replacement: 步骤 2 中的图像 1,3 Infant Optics DXR-8 Speaker Replacement: 步骤 2 中的图像 2,3 Infant Optics DXR-8 Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Speaker Replacement: 步骤 3 中的图像 1,3 Infant Optics DXR-8 Speaker Replacement: 步骤 3 中的图像 2,3 Infant Optics DXR-8 Speaker Replacement: 步骤 3 中的图像 3,3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
  5. Infant Optics DXR-8 Speaker Replacement: 步骤 5 中的图像 1,1
    • Lift the speaker from casing using metal spudger.
    • Place new 8W speaker in the casing and connect wire.
结论
3等其他人完成本指南。
Larsha Johnson
于08/26/15注册
526 声望
创作了3篇指南
团队
USF Tampa, Team 6-4, Remmell Fall 2015 USF Tampa, Team 6-4, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G4
4 名成员
创作了3篇指南
5条评论
Where to purchase the replacement speaker?
Keiundra Joiner - 回复
Where can we purchase the replacement 8w speaker part
lea placek - 回复
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Ryan Ernde - 回复
Thanks for this. Found something on Ali Express, just need to figure out the right size
https://www.aliexpress.us/item/325680361...
itryit -
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
Mark Ruddy - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 84
总计 17,007
