跳转到主内容
Infant Optics DXR-8 Monitor Screen Replacement
你所需要的
  1. Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: 步骤 1 中的图像 1,3 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: 步骤 1 中的图像 2,3 Infant Optics DXR-8 Monitor Screen Replacement, Internal Monitor Components: 步骤 1 中的图像 3,3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Screen Replacement: 步骤 2 中的图像 1,3 Infant Optics DXR-8 Monitor Screen Replacement: 步骤 2 中的图像 2,3 Infant Optics DXR-8 Monitor Screen Replacement: 步骤 2 中的图像 3,3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Screen Replacement: 步骤 3 中的图像 1,3 Infant Optics DXR-8 Monitor Screen Replacement: 步骤 3 中的图像 2,3 Infant Optics DXR-8 Monitor Screen Replacement: 步骤 3 中的图像 3,3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: 步骤 4 中的图像 1,3 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: 步骤 4 中的图像 2,3 Infant Optics DXR-8 Monitor Screen Replacement, Monitor Screen: 步骤 4 中的图像 3,3
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Screen Replacement: 步骤 5 中的图像 1,2 Infant Optics DXR-8 Monitor Screen Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Screen Replacement: 步骤 6 中的图像 1,1
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Screen Replacement: 步骤 7 中的图像 1,3 Infant Optics DXR-8 Monitor Screen Replacement: 步骤 7 中的图像 2,3 Infant Optics DXR-8 Monitor Screen Replacement: 步骤 7 中的图像 3,3
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
结论
另外一个人完成了本指南。
3条评论
Hey Daniel!
Thanks for sharing ??
Where did you get the replacement part?
Ro Brandi - 回复
On Amazon is the quickest option.
Hilitand LQ035NC111 LCD Display, 3.5inch TFT RGB LCD Display Module 320 x 240 Display Panel LQ035NC111 54pin LCD
Stebe -
Just completed the screen change, it works great! Thanks so much for this step by step guide.
The screen I ordered came with the metal brackets. Since the base was glued to the motherboard, it took a few extra steps of de-casing the one I got and re-casing onto the board. But worked fine.
I ordered: https://www.amazon.com/dp/B07NYN5PK2?psc...
James Quinlan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 73
总计 4,612
