跳转到主内容
Infant Optics DXR-8 Battery Replacement
  1. Infant Optics DXR-8 Battery  Replacement, Battery: 步骤 1 中的图像 1,3 Infant Optics DXR-8 Battery  Replacement, Battery: 步骤 1 中的图像 2,3 Infant Optics DXR-8 Battery  Replacement, Battery: 步骤 1 中的图像 3,3
    • Begin by holding the Monitor so that the backside is flipped up. This is where your battery is located.
    • Slide the battery panel downwards to detach it completely. The battery should be completely visible.
  2. Infant Optics DXR-8 Battery  Replacement: 步骤 2 中的图像 1,3 Infant Optics DXR-8 Battery  Replacement: 步骤 2 中的图像 2,3 Infant Optics DXR-8 Battery  Replacement: 步骤 2 中的图像 3,3
    • Now that your battery is exposed, begin to take the battery out. The only thing keeping the battery in the battery port should be the plug.
    • Now unplug the battery from the battery port. The plug is small so be careful locating it.
    • The battery and plug should be completely out of the battery port.
结论
To reassemble your device, follow these instructions in reverse order
4等其他人完成本指南。
团队
Cal Poly, Team 13-4, Banghart Winter 2017 Cal Poly, Team 13-4, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S13G4
4 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 34
总计 12,098
