跳转到主内容
Infant Optics DXR-5 Monitor Screen Replacement
你所需要的
  1. Infant Optics DXR-5 Monitor Screen Replacement, Battery: 步骤 1 中的图像 1,2 Infant Optics DXR-5 Monitor Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Press on the blue clip on the back and slide it down.
    • In the second picture there is a slight gap at the top of the blue clip.
  2. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 2 中的图像 1,1
    • Pull the blue clip away from the body of the hand held monitor.
  3. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 3 中的图像 1,1
    • Slide the rear white panel off as shown.
  4. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 4 中的图像 1,2 Infant Optics DXR-5 Monitor Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the battery by pushing in on the right side and then pulling the battery up and out of the body of the hand held monitor.
  5. Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: 步骤 5 中的图像 1,3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: 步骤 5 中的图像 2,3 Infant Optics DXR-5 Monitor Screen Replacement, Monitor Screen: 步骤 5 中的图像 3,3
    • Remove the four 6.0 mm Phillips screws located on the back of the hand held monitor using a Phillips #2 screwdriver.
    • There are two types of screws. Be sure to return the screws to their respective holes upon reassembly.
  6. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 6 中的图像 1,2 Infant Optics DXR-5 Monitor Screen Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the clear face plate on the front of the hand held monitor using a plastic spudger and a suction cup.
    • Use a heat source to loosen the adhesive around the edge of the face plate before applying any pressure to the face plate.
  7. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 7 中的图像 1,2 Infant Optics DXR-5 Monitor Screen Replacement: 步骤 7 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that are exposed after removing the face plate.
  8. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 8 中的图像 1,2 Infant Optics DXR-5 Monitor Screen Replacement: 步骤 8 中的图像 2,2
    • Using a drill carefully drill out the plastic posts that connect the mother board to the face plate.
  9. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 9 中的图像 1,2 Infant Optics DXR-5 Monitor Screen Replacement: 步骤 9 中的图像 2,2
    • Carefully open the hand held monitor and flip the screen (highlighted in red) out of the way.
  10. Infant Optics DXR-5 Monitor Screen Replacement: 步骤 10 中的图像 1,2 Infant Optics DXR-5 Monitor Screen Replacement: 步骤 10 中的图像 2,2
    • Remove the hand held monitor screen from the mother board by carefully pulling from the point where it is attached with an adhesive to the mother board.
结论
另外一个人完成了本指南。
Charles Neal
于08/31/15注册
687 声望
创作了5篇指南
团队
USF Tampa, Team 6-2, Remmell Fall 2015 USF Tampa, Team 6-2, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G2
5 名成员
创作了5篇指南
1指南评论
Any ideas on where to source the replacement screen?
Abdullah - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 2,168
