跳转到主内容
Infant Optics DXR-5 Camera Lens Replacement
你所需要的
  1. Infant Optics DXR-5 Camera Lens Replacement, Camera: 步骤 1 中的图像 1,2 Infant Optics DXR-5 Camera Lens Replacement, Camera: 步骤 1 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the four, 6.0 mm Phillips screws from the back of the camera unit.
  2. Infant Optics DXR-5 Camera Lens Replacement: 步骤 2 中的图像 1,2 Infant Optics DXR-5 Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Pull up on the two beige tabs to the left and right of the ribbon connected to the camera.
    • Pull the ribbon straight out from the camera.
  3. Infant Optics DXR-5 Camera Lens Replacement: 步骤 3 中的图像 1,2 Infant Optics DXR-5 Camera Lens Replacement: 步骤 3 中的图像 2,2
    • Remove the front face plate of the camera unit by carefully pulling it off.
  4. Infant Optics DXR-5 Camera Lens Replacement, Camera Lens: 步骤 4 中的图像 1,2 Infant Optics DXR-5 Camera Lens Replacement, Camera Lens: 步骤 4 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the two 6.0 mm Phillips screws that hold the camera lens on.
    • These two screws have a different thread than the four screws that secure the camera unit's housing.
结论
Charles Neal
于08/31/15注册
687 声望
创作了5篇指南
团队
USF Tampa, Team 6-2, Remmell Fall 2015 USF Tampa, Team 6-2, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G2
5 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 729
