本指南有最近更改,您可查看未经巡查的最新版本。
简介
Follow this guide to remove the pump rod from the pump in order to replace or repair it.
你所需要的
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
即将完成!
结论
