本指南有最近更改,您可查看未经巡查的最新版本。
简介
Follow this guide to remove the head of the India Mark III. You can then replace it or clean it, as necessary.
你所需要的
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
即将完成!
结论
