简介
Follow this guide to remove the axle and the handle from the India Mark III. You can then replace or repair either component.
配件
没有特定配件。
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Use a wrench to loosen the nut on the end of the handle axle.
Remove the nut and washer from the end of the axle.
即将完成!
结论
