本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to replace the riser main with the help of a tripod.
The riser main can, alternatively, be replaced using lifting spanners, but a tripod allows the process to be done by two people. Still use caution when using a tripod.
你所需要的
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
Screw a T-handle onto the top of the pump rod. Tighten the T-handle up against the jam nut.
Lower the tripod pipe vise to the top of the riser main.
Close the tripod pipe vise around the riser main, and lock it shut.
