当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use a wrench to remove the bolt on the top of the cover plate.
When replacing the cover plate, this bolt only needs to be hand tight.
Remove the top cover by pulling it straight off the pump.
Store the top cover in a sanitary place, preferably above ground, to prevent contamination.
Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
Place the spacer around the pump rod and under the chain attachment point.
Make sure the spacer is beveled side down, and flat side up.
Lift the pump lever until there is no tension in the chain and hold it in this position.
Remove the bolt connecting the chain to the pump handle.
Remove the chain from the handle.
There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
Continue supporting the pump handle so the pump head doesn't fall off when all the bolts are removed.
Remove the 4 bolts on the base of the water tank.
Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
取消:我没有完成这个指南。
与4其他贡献者
于08/22/11注册
86,704 声望
创作了87篇指南
徽章: 43
+ 40更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 662
