跳转到主内容
修复你的物品
维修的权力
商店
已存档
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
已存档
简介
Remove and or replace the head section of the India Mark II water hand pump.
配件
没有特定配件。
  1. Use a wrench to remove the bolt on the top of the cover plate.
    • Use a wrench to remove the bolt on the top of the cover plate.
    • When replacing the cover plate, this bolt only needs to be hand tight.
  2. Remove the top cover by pulling it straight off the pump.
    • Remove the top cover by pulling it straight off the pump.
    • Store the top cover in a sanitary place, preferably above ground, to prevent contamination.
  3. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  4. Pull the pump handle all the way down and hold it in this position, exposing the pump rod. Place the spacer around the pump rod and under the chain attachment point. Make sure the spacer is beveled side down, and flat side up.
    • Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
    • Place the spacer around the pump rod and under the chain attachment point.
    • Make sure the spacer is beveled side down, and flat side up.
    • Lift the pump lever until there is no tension in the chain and hold it in this position.
  5. Remove the bolt connecting the chain to the pump handle. Remove the chain from the handle.
    • Remove the bolt connecting the chain to the pump handle.
    • Remove the chain from the handle.
  6. There are 4 bolts securing the head section to the water tank, located at the corners of head section base. Continue supporting the pump handle so the pump head doesn't fall off when all the bolts are removed. Remove the 4 bolts on the base of the water tank.
    • There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
    • Continue supporting the pump handle so the pump head doesn't fall off when all the bolts are removed.
    • Remove the 4 bolts on the base of the water tank.
  7. Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
    • Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
结论
Phillip Takahashi
于2011年08月22日注册
81,956 信誉积分
创作了87篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 661
