跳转到主内容
加入维修社区 - 创建账户
India Mark II Head Section Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. India Mark II Head Section Replacement, Cover Plate: 步骤 1 中的图像 1,1
    • Use a wrench to remove the bolt on the top of the cover plate.
    • When replacing the cover plate, this bolt only needs to be hand tight.
  2. India Mark II Head Section Replacement: 步骤 2 中的图像 1,1
    • Remove the top cover by pulling it straight off the pump.
    • Store the top cover in a sanitary place, preferably above ground, to prevent contamination.
  3. India Mark II Head Section Replacement, Head Section: 步骤 3 中的图像 1,3 India Mark II Head Section Replacement, Head Section: 步骤 3 中的图像 2,3 India Mark II Head Section Replacement, Head Section: 步骤 3 中的图像 3,3
    • Pull the pump handle all the way down and hold it in this position, exposing the pump rod.
    • Place the spacer around the pump rod and under the chain attachment point.
    • Make sure the spacer is beveled side down, and flat side up.
    • Lift the pump lever until there is no tension in the chain and hold it in this position.
  4. India Mark II Head Section Replacement: 步骤 4 中的图像 1,2 India Mark II Head Section Replacement: 步骤 4 中的图像 2,2
    • Remove the bolt connecting the chain to the pump handle.
    • Remove the chain from the handle.
  5. India Mark II Head Section Replacement: 步骤 5 中的图像 1,3 India Mark II Head Section Replacement: 步骤 5 中的图像 2,3 India Mark II Head Section Replacement: 步骤 5 中的图像 3,3
    • There are 4 bolts securing the head section to the water tank, located at the corners of head section base.
    • Continue supporting the pump handle so the pump head doesn't fall off when all the bolts are removed.
    • Remove the 4 bolts on the base of the water tank.
  6. India Mark II Head Section Replacement: 步骤 6 中的图像 1,1
    • Lift the pump head off of the water tank and place in a sanitary place, preferably above ground, to prevent contamination.
结论
Phillip Takahashi
于08/22/11注册
87,738 声望
创作了87篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 25
总计 731
