跳转到主内容
India Mark II Head Replacement
你所需要的
  1. India Mark II Head Replacement, Access Door: 步骤 1 中的图像 1,2 India Mark II Head Replacement, Access Door: 步骤 1 中的图像 2,2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Head Replacement: 步骤 2 中的图像 1,3 India Mark II Head Replacement: 步骤 2 中的图像 2,3 India Mark II Head Replacement: 步骤 2 中的图像 3,3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Head Replacement: 步骤 3 中的图像 1,2 India Mark II Head Replacement: 步骤 3 中的图像 2,2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. India Mark II Head Replacement, Chain: 步骤 4 中的图像 1,3 India Mark II Head Replacement, Chain: 步骤 4 中的图像 2,3 India Mark II Head Replacement, Chain: 步骤 4 中的图像 3,3
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. India Mark II Head Replacement: 步骤 5 中的图像 1,3 India Mark II Head Replacement: 步骤 5 中的图像 2,3 India Mark II Head Replacement: 步骤 5 中的图像 3,3
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. India Mark II Head Replacement: 步骤 6 中的图像 1,3 India Mark II Head Replacement: 步骤 6 中的图像 2,3 India Mark II Head Replacement: 步骤 6 中的图像 3,3
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  7. India Mark II Head Replacement: 步骤 7 中的图像 1,3 India Mark II Head Replacement: 步骤 7 中的图像 2,3 India Mark II Head Replacement: 步骤 7 中的图像 3,3
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  8. India Mark II Head Replacement: 步骤 8 中的图像 1,3 India Mark II Head Replacement: 步骤 8 中的图像 2,3 India Mark II Head Replacement: 步骤 8 中的图像 3,3
    • Remove the nut from the chain bolt.
  9. India Mark II Head Replacement: 步骤 9 中的图像 1,2 India Mark II Head Replacement: 步骤 9 中的图像 2,2
    • Remove the washer from the chain bolt.
  10. India Mark II Head Replacement: 步骤 10 中的图像 1,2 India Mark II Head Replacement: 步骤 10 中的图像 2,2
    • Remove the chain bolt.
  11. India Mark II Head Replacement: 步骤 11 中的图像 1,3 India Mark II Head Replacement: 步骤 11 中的图像 2,3 India Mark II Head Replacement: 步骤 11 中的图像 3,3
    • Pull the top of the chain straight off of the pump handle.
  12. India Mark II Head Replacement, Head: 步骤 12 中的图像 1,3 India Mark II Head Replacement, Head: 步骤 12 中的图像 2,3 India Mark II Head Replacement, Head: 步骤 12 中的图像 3,3
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  13. India Mark II Head Replacement: 步骤 13 中的图像 1,3 India Mark II Head Replacement: 步骤 13 中的图像 2,3 India Mark II Head Replacement: 步骤 13 中的图像 3,3
    • Remove the two bolts and nuts from the handle side.
  14. India Mark II Head Replacement: 步骤 14 中的图像 1,2 India Mark II Head Replacement: 步骤 14 中的图像 2,2
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  15. India Mark II Head Replacement: 步骤 15 中的图像 1,3 India Mark II Head Replacement: 步骤 15 中的图像 2,3 India Mark II Head Replacement: 步骤 15 中的图像 3,3
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
结论
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,732篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 49
过去 30 天: 84
总计 3,079
