简介
This guide will guide you through removing the chain for cleaning or replacing. Be sure to keep all components in a sanitary place when storing them.
你所需要的
Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
Remove the two bolts from the handle side of the pump head.
Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
另外一个人完成了本指南。
