简介
Replace the light tunnel if experiencing dark bands across or on the edges of the screen.
For this project you'll need a can of compressed air to clean the inside if it's dirty. You'll also need a Torx screwdriver and a metal spudger.
你所需要的
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
With the lens facing you, remove the following screws:
Using the Phillips #1 screwdriver, remove the (3) three 1.25 cm gold screws holding the metal grate between the color wheel unit and the bulb.
Using the Phillips #1 screwdriver, remove the (2) two 2 cm gold screws on the right side of the lens house.
Using the Phillips #1 screwdriver and a bent driver, remove the (4) four 2 cm screws on the back of the lens house.
To reassemble the device, follow these instructions in reverse order.
