跳转到主内容
InFocus Screenplay 4805 Light Tunnel Replacement
你所需要的
  1. InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: 步骤 1 中的图像 1,3 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: 步骤 1 中的图像 2,3 InFocus Screenplay 4805 Light Tunnel Replacement, Top Panel: 步骤 1 中的图像 3,3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 2 中的图像 1,2 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 2 中的图像 2,2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 3 中的图像 1,3 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 3 中的图像 2,3 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 3 中的图像 3,3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 4 中的图像 1,1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 5 中的图像 1,1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
  6. InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: 步骤 6 中的图像 1,3 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: 步骤 6 中的图像 2,3 InFocus Screenplay 4805 Light Tunnel Replacement, Light Tunnel: 步骤 6 中的图像 3,3
    • With the lens facing you, remove the following screws:
    • Using the Phillips #1 screwdriver, remove the (3) three 1.25 cm gold screws holding the metal grate between the color wheel unit and the bulb.
    • Using the Phillips #1 screwdriver, remove the (2) two 2 cm gold screws on the right side of the lens house.
    • Using the Phillips #1 screwdriver and a bent driver, remove the (4) four 2 cm screws on the back of the lens house.
  7. InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 7 中的图像 1,3 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 7 中的图像 2,3 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 7 中的图像 3,3
    • Using a Phillips #0 screwdriver remove the three 1 cm black screws from the lens house.
    • Remove the lens unit.
  8. InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 8 中的图像 1,3 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 8 中的图像 2,3 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 8 中的图像 3,3
    • Using the Phillips #0 head, unscrew the four 1 cm black screws.
    • Remove the metal casings holding the tunnel in place.
  9. InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 9 中的图像 1,2 InFocus Screenplay 4805 Light Tunnel Replacement: 步骤 9 中的图像 2,2
    • Using the Phillips #0 head, unscrew the black 0.5 cm screw on the bottom of the lens house.
    • Remove the light tunnel.
结论
To reassemble the device, follow these instructions in reverse order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 827
