Insert an opening pick into the seam on side of the remote, even with the InFocus Label.
Slide the opening pick along the side of the remote, moving towards the buttons.
There is a plastic tab that holds the covers to the base, located even with the Source button. Push the pick through with a bit more force here to disconnect the cover.
Lift the motherboard up and out of the silver base.
There are two springs attached to the bottom of the motherboard that can get stuck in the base. Wiggle the board as you pull it up and out to release it.
