介绍
Use this guide to replace broken, torn or ugly buttons on your InFocus Remote.
  1. Use your finger to press the tab on the battery cover. Lift the cover up and out.
    • Use your finger to press the tab on the battery cover.
    • Lift the cover up and out.
  2. Use your finger to lift the two AA batteries up and out of the remote. Use your finger to lift the two AA batteries up and out of the remote.
    • Use your finger to lift the two AA batteries up and out of the remote.
  3. Remove the three 9mm Phillips #00 screws located on the backside of the remote.
    • Remove the three 9mm Phillips #00 screws located on the backside of the remote.
  4. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
  5. Insert a plastic opening tool into the seam between the black top cover and silver base at the bottom edge of the remote. Carefully pry the top cover up and away from the base.
    • Insert a plastic opening tool into the seam between the black top cover and silver base at the bottom edge of the remote.
    • Carefully pry the top cover up and away from the base.
  6. Insert an opening pick into the seam on side of the remote, even with the InFocus Label. Slide the opening pick along the side of the remote, moving towards the buttons. There is a plastic tab that holds the covers to the base, located even with the Source button. Push the pick through with a bit more force here to disconnect the cover.
    • Insert an opening pick into the seam on side of the remote, even with the InFocus Label.
    • Slide the opening pick along the side of the remote, moving towards the buttons.
    • There is a plastic tab that holds the covers to the base, located even with the Source button. Push the pick through with a bit more force here to disconnect the cover.
  7. Repeat the previous step on the other side of the remote, working from the InFocus label towards the buttons until the entire cover is loose. Repeat the previous step on the other side of the remote, working from the InFocus label towards the buttons until the entire cover is loose. Repeat the previous step on the other side of the remote, working from the InFocus label towards the buttons until the entire cover is loose.
    • Repeat the previous step on the other side of the remote, working from the InFocus label towards the buttons until the entire cover is loose.
  8. Firmly grasp the cover and lift it away from the remote. Firmly grasp the cover and lift it away from the remote.
    • Firmly grasp the cover and lift it away from the remote.
  9. Lift the button pad up and out of the remote. Lift the button pad up and out of the remote.
    • Lift the button pad up and out of the remote.
结论
Paige Reisman
于2014年04月07日注册
17,783 Reputation
创作了15篇指南
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 129
