工具
配件
没有特定配件。
Flip the projector right-side up and turn it so that the back ports are facing you.
Remove the 7mm metallic hex screws using the flat-head screwdriver.
Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
Once the main board has been removed, carefully lift the fans upward. Make sure no cables are tangled in the process.
另外一个人完成了本指南。
