跳转到主内容
加入维修社区 - 创建账户
InFocus LP435Z Secondary Fan Replacement
你所需要的
  1. InFocus LP435Z Secondary Fan Replacement, External Shell: 步骤 1 中的图像 1,2 InFocus LP435Z Secondary Fan Replacement, External Shell: 步骤 1 中的图像 2,2
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
    询问修复机器人
    添加评论
  2. InFocus LP435Z Secondary Fan Replacement: 步骤 2 中的图像 1,2 InFocus LP435Z Secondary Fan Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
    询问修复机器人
    添加评论
  3. InFocus LP435Z Secondary Fan Replacement: 步骤 3 中的图像 1,2 InFocus LP435Z Secondary Fan Replacement: 步骤 3 中的图像 2,2
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
    询问修复机器人
    添加评论
  4. InFocus LP435Z Secondary Fan Replacement: 步骤 4 中的图像 1,3 InFocus LP435Z Secondary Fan Replacement: 步骤 4 中的图像 2,3 InFocus LP435Z Secondary Fan Replacement: 步骤 4 中的图像 3,3
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
    询问修复机器人
    添加评论
  5. InFocus LP435Z Secondary Fan Replacement: 步骤 5 中的图像 1,2 InFocus LP435Z Secondary Fan Replacement: 步骤 5 中的图像 2,2
    • Lift away the top case plate and set it aside.
    询问修复机器人
    添加评论
  6. InFocus LP435Z Secondary Fan Replacement, Secondary Fan: 步骤 6 中的图像 1,2 InFocus LP435Z Secondary Fan Replacement, Secondary Fan: 步骤 6 中的图像 2,2
    • Unplug the small ribbon cable connecting the DLP board to the motherboard. It is obstructing the secondary fan power cable.
    • Unplug the secondary fan's power cable from the motherboard.
    询问修复机器人
    添加评论
  7. InFocus LP435Z Secondary Fan Replacement: 步骤 7 中的图像 1,2 InFocus LP435Z Secondary Fan Replacement: 步骤 7 中的图像 2,2
    • Remove the two Phillips #1 8.5mm screws holding the secondary fan in place.
    • The second screw is close to the bottom of the projector and may be difficult to see.
    询问修复机器人
    添加评论
  8. InFocus LP435Z Secondary Fan Replacement: 步骤 8 中的图像 1,1
    • Remove the secondary fan, by pulling straight up and out of projector.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
Cal Poly, Team 20-3, Maness Winter 2013 Cal Poly, Team 20-3, Maness Winter 2013 的会员
CPSU-MANESS-W13S20G3
4 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 775
