Introduction
The power supply is what transforms the alternating current electricity from a wall outlet into a lower voltage direct current that is usable by the projector. There are many sensitive electronics in a power supply, and a power surge or other electrical issue can fry capacitors and other delicate components, breaking the power supply and preventing the projector from turning on.
The power supply in this projector has an enclosure which the speaker and main fan are mounted on, and the base of the enclosure with the attached power supply can be removed and replaced.
Tools
Parts
No parts specified.
Place the projector on its back (buttons down) with the lens facing away from you.
Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
Flip the projector over and turn around so that the lens faces you.
Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
Rotate the power supply so that the main fan enclosure faces to the right, with the motherboard mounting pegs on top.
Remove the two #2 Phillips 7mm screws on the side of the power supply.
Remove two more #2 Phillips 7mm screws on the opposite side of the power supply.
Rotate the power supply so the fan faces towards you, and remove a fifth #2 Phillips 7mm screw from just under the foam pad.
2 other people completed this guide.
