跳转到主内容
加入维修社区 - 创建账户
InFocus IN3114 Lamp Replacement
你所需要的
  1. InFocus IN3114 Lamp Replacement, Top Plate: 步骤 1 中的图像 1,2 InFocus IN3114 Lamp Replacement, Top Plate: 步骤 1 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
  2. InFocus IN3114 Lamp Replacement: 步骤 2 中的图像 1,3 InFocus IN3114 Lamp Replacement: 步骤 2 中的图像 2,3 InFocus IN3114 Lamp Replacement: 步骤 2 中的图像 3,3
    • Use your hands to slide the top plate off of the projector.
    • Lift and remove the plate.
  3. InFocus IN3114 Lamp Replacement, Lamp: 步骤 3 中的图像 1,1
    • Use a Phillips #1 screwdriver to unscrew the two 9 mm screws on the top of the lamp housing unit.
    • Screws will not come all the way out. It is best to just loosen them as much as possible.
  4. InFocus IN3114 Lamp Replacement: 步骤 4 中的图像 1,1
    • Use your hands to pull up on the silver handle and remove the lamp housing unit.
  5. InFocus IN3114 Lamp Replacement: 步骤 5 中的图像 1,2 InFocus IN3114 Lamp Replacement: 步骤 5 中的图像 2,2
    • Once the lamp housing is removed flip it over where silver pull tab is face down.
    • Use a Phillips #00 screwdriver to remove the 5 mm screw from the right side of the lamp housing unit.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws from the top of the unit.
  6. InFocus IN3114 Lamp Replacement: 步骤 6 中的图像 1,1
    • Use hands to pull off the black unit cover.
  7. InFocus IN3114 Lamp Replacement: 步骤 7 中的图像 1,2 InFocus IN3114 Lamp Replacement: 步骤 7 中的图像 2,2
    • Once the cover is removed, flip the housing unit so the bulb is face down.
    • Remove the four 4 mm screws with a Phillips #00 screwdriver.
  8. InFocus IN3114 Lamp Replacement: 步骤 8 中的图像 1,2 InFocus IN3114 Lamp Replacement: 步骤 8 中的图像 2,2
    • Use hands to pull out the bulb and silver cover.
    • Gently pull on the two wires that connect the bulb to its housing to disconnect them.
  9. InFocus IN3114 Lamp Replacement: 步骤 9 中的图像 1,2 InFocus IN3114 Lamp Replacement: 步骤 9 中的图像 2,2
    • Once wires are disconnected, Remove the bulb from the silver cover and replace.
结论
Lily Calvert
于03/21/22注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 750
