跳转到主内容
InFocus IN3104 Top Cover Replacement
你所需要的
  1. InFocus IN3104 Top Cover Replacement, Top Cover: 步骤 1 中的图像 1,3 InFocus IN3104 Top Cover Replacement, Top Cover: 步骤 1 中的图像 2,3 InFocus IN3104 Top Cover Replacement, Top Cover: 步骤 1 中的图像 3,3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Top Cover Replacement: 步骤 2 中的图像 1,3 InFocus IN3104 Top Cover Replacement: 步骤 2 中的图像 2,3 InFocus IN3104 Top Cover Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 182
