跳转到主内容
InFocus IN3104 Speaker Replacement
你所需要的
  1. InFocus IN3104 Speaker Replacement, Top Cover: 步骤 1 中的图像 1,3 InFocus IN3104 Speaker Replacement, Top Cover: 步骤 1 中的图像 2,3 InFocus IN3104 Speaker Replacement, Top Cover: 步骤 1 中的图像 3,3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Speaker Replacement: 步骤 2 中的图像 1,3 InFocus IN3104 Speaker Replacement: 步骤 2 中的图像 2,3 InFocus IN3104 Speaker Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: 步骤 3 中的图像 1,2 InFocus IN3104 Speaker Replacement, InFocus IN3104 Metal Cover Disassembly: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Speaker Replacement: 步骤 4 中的图像 1,3 InFocus IN3104 Speaker Replacement: 步骤 4 中的图像 2,3 InFocus IN3104 Speaker Replacement: 步骤 4 中的图像 3,3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 InFocus IN3104 Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Unplug the speaker wire that is located right behind the cooling fan.
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws on the frame brackets.
  6. InFocus IN3104 Speaker Replacement: 步骤 6 中的图像 1,3 InFocus IN3104 Speaker Replacement: 步骤 6 中的图像 2,3 InFocus IN3104 Speaker Replacement: 步骤 6 中的图像 3,3
    • Remove the side panel.
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws.
    • Remove the speaker by pulling it straight out.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 202
