跳转到主内容
加入维修社区 - 创建账户
In-Ground Pool Filter Replacement
你所需要的
  1. In-Ground Pool Filter Replacement, Filter: 步骤 1 中的图像 1,2 In-Ground Pool Filter Replacement, Filter: 步骤 1 中的图像 2,2
    • Make sure the pool pump switch is off.
  2. In-Ground Pool Filter Replacement: 步骤 2 中的图像 1,3 In-Ground Pool Filter Replacement: 步骤 2 中的图像 2,3 In-Ground Pool Filter Replacement: 步骤 2 中的图像 3,3
    • Unscrew the metal ring bracket that is on the filter housing in order to remove the top half of the filter housing (lid). Turn the handle in a counter-clock wise motion until it is completely loose and the screw can be removed.
  3. In-Ground Pool Filter Replacement: 步骤 3 中的图像 1,3 In-Ground Pool Filter Replacement: 步骤 3 中的图像 2,3 In-Ground Pool Filter Replacement: 步骤 3 中的图像 3,3
    • Take the metal ring bracket off.
  4. In-Ground Pool Filter Replacement: 步骤 4 中的图像 1,2 In-Ground Pool Filter Replacement: 步骤 4 中的图像 2,2
    • Remove the top half of the filter housing.
  5. In-Ground Pool Filter Replacement: 步骤 5 中的图像 1,3 In-Ground Pool Filter Replacement: 步骤 5 中的图像 2,3 In-Ground Pool Filter Replacement: 步骤 5 中的图像 3,3
    • Remove the O-ring.
  6. In-Ground Pool Filter Replacement: 步骤 6 中的图像 1,3 In-Ground Pool Filter Replacement: 步骤 6 中的图像 2,3 In-Ground Pool Filter Replacement: 步骤 6 中的图像 3,3
    • Unscrew the filter cap in a counter clock wise motion until it comes off.
  7. In-Ground Pool Filter Replacement: 步骤 7 中的图像 1,3 In-Ground Pool Filter Replacement: 步骤 7 中的图像 2,3 In-Ground Pool Filter Replacement: 步骤 7 中的图像 3,3
    • Take the pool filter out and place on the ground. Put the new filter in and to put it all back together you can simply follow these directions in reverse order.
    • While the filter housing is apart, you should inspect the O-ring to determine if it has any cracks or tears. If so, replace it with a new O-ring. If it still appears to be in decent condition, then continue to use it and apply a little lube. NEVER use Vaseline or any other petroleum-based lubricant on pool parts. Look for silicone-based lubes.
结论
Every pool has different size filters. This guide is a general reference of how to replace a filter and return the filter back to the pump. To reassemble your device, follow these instructions in reverse order.
4等其他人完成本指南。
团队
Pasco Hernando, Team 5-2, Prince Fall 2016 Pasco Hernando, Team 5-2, Prince Fall 2016 的会员
PHSC-PRINCE-F16S5G2
1 名成员
创作了1篇指南
1指南评论
Which model is this?
Osvaldo walle - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 18
过去 30 天: 59
总计 1,274
