Turn on your mirror to see which light bulb is not working.
Now that you know which bulb isn't working, turn off the mirror and disconnect it from the wall outlet to avoid any injuries.
Turn the light bulb counter clockwise to remove it from the mirror.
Make sure the light bulb that you bought is the same model and wattage as the one you removed.
Place the new light bulb in its socket and turn it clockwise to secure it.
Make sure that the bulb is secured in place.
If it's not well-secured, the bulb won't light up when the mirror is turned on.
Plug the mirror back into the outlet.
Turn on the mirror and check that the new bulb works.
取消:我没有完成这个指南。
与1其他贡献者
于04/17/21注册
157 声望
撰写一个指南
徽章: 2
CSULA-HARRIS-S21S1G80
1 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 49
总计 903
