跳转到主内容
Impression i7 USB Port Replacement
你所需要的
  1. Impression i7 USB Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 USB Port Replacement: 步骤 2 中的图像 1,1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 USB Port Replacement: 步骤 3 中的图像 1,1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 USB Port Replacement: 步骤 4 中的图像 1,2 Impression i7 USB Port Replacement: 步骤 4 中的图像 2,2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 USB Port Replacement: 步骤 5 中的图像 1,1
    • Desolder the positive and negative leads.
  6. Impression i7 USB Port Replacement: 步骤 6 中的图像 1,2 Impression i7 USB Port Replacement: 步骤 6 中的图像 2,2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 USB Port Replacement, USB Port: 步骤 7 中的图像 1,1
    • Remove the five 5 mm screws from the motherboard, using the #0 Phillips Screwdriver.
  8. Impression i7 USB Port Replacement: 步骤 8 中的图像 1,2 Impression i7 USB Port Replacement: 步骤 8 中的图像 2,2
    • Using the plastic opening tool tool, pry back the 4 four clips to release the motherboard.
  9. Impression i7 USB Port Replacement: 步骤 9 中的图像 1,2 Impression i7 USB Port Replacement: 步骤 9 中的图像 2,2
    • Desolder the eight solder joints holding the USB Port in place.
结论
Cole Beaver
于11/05/18注册
390 声望
创作了3篇指南
团队
IUPUI, Team S1-G5, Baechle Fall 2018 IUPUI, Team S1-G5, Baechle Fall 2018 的会员
IUPUI-BAECHLE-F18S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 164
