跳转到主内容
加入维修社区 - 创建账户
Impression i7 Battery Replacement
你所需要的
  1. Impression i7 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 Battery Replacement: 步骤 2 中的图像 1,1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 Battery Replacement: 步骤 3 中的图像 1,1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 Battery Replacement: 步骤 4 中的图像 1,2 Impression i7 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 Battery Replacement: 步骤 5 中的图像 1,1
    • Desolder the positive and negative leads.
  6. Impression i7 Battery Replacement: 步骤 6 中的图像 1,2 Impression i7 Battery Replacement: 步骤 6 中的图像 2,2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
结论
2等其他人完成本指南。
Cole Beaver
于11/05/18注册
417 声望
创作了3篇指南
团队
IUPUI, Team S1-G5, Baechle Fall 2018 IUPUI, Team S1-G5, Baechle Fall 2018 的会员
IUPUI-BAECHLE-F18S1G5
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 323
