跳转到主内容
Imation Superdisk USB Drive Plastic Arm Replacement
你所需要的
  1. Imation Superdisk USB Drive Plastic Arm Replacement, Plastic Housing: 步骤 1 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement, Plastic Housing: 步骤 1 中的图像 2,2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 2 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 2 中的图像 2,2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 3 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 3 中的图像 2,2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 4 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 4 中的图像 2,2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 5 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 5 中的图像 2,2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 6 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 6 中的图像 2,2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Plastic Arm Replacement, Metal Casing: 步骤 7 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement, Metal Casing: 步骤 7 中的图像 2,2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 8 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 8 中的图像 2,2
    • Slide disk drive out of metal casing.
  9. Imation Superdisk USB Drive Plastic Arm Replacement, Daughter Board: 步骤 9 中的图像 1,1
    • Flip the disk drive over so the the plug on the daughter board is visible.
  10. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 10 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 10 中的图像 2,2
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  11. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 11 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 11 中的图像 2,2
    • Gently pull on the daughter board until it separates from the device.
  12. Imation Superdisk USB Drive Plastic Arm Replacement, Disc Drive Casing: 步骤 12 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement, Disc Drive Casing: 步骤 12 中的图像 2,2
    • Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
    • You may have to use the plastic spudger in several spots along the metal casing.
  13. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 13 中的图像 1,1
    • lift the disk drive completely out of the metal casing and set it aside.
  14. Imation Superdisk USB Drive Plastic Arm Replacement, Plastic Arm: 步骤 14 中的图像 1,1
    • Flip the device over so the plastic arm is face up.
  15. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 15 中的图像 1,2 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 15 中的图像 2,2
    • Remove the small spring that connects the plastic arm to the disk drive.
    • To the keep the spring from flying in the air and getting lost, put your finger on one end of the spring to hold it in place while you detach the other end. It does not matter which end you chose to detach first.
  16. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 16 中的图像 1,3 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 16 中的图像 2,3 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 16 中的图像 3,3
    • Locate the tab with a raised dot on the immobile end of the plastic arm.
    • Apply pressure on the plastic tab and slide it backwards to release that end of the arm from the disk drive.
  17. Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 17 中的图像 1,3 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 17 中的图像 2,3 Imation Superdisk USB Drive Plastic Arm Replacement: 步骤 17 中的图像 3,3
    • Rotate the plastic arm until it fits through the opening in the disk drive and pull it out.
    • Completely remove the plastic arm from the disk drive.
    • Replace the arm if it is broken or set it aside and continue to your next task.
结论
Brittini
于02/11/14注册
22 声望
撰写一个指南
团队
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G2
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 582
