跳转到主内容
加入维修社区 - 创建账户
Imation Superdisk USB Drive Metal Casing Replacement
你所需要的
  1. Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: 步骤 1 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement, Plastic Housing: 步骤 1 中的图像 2,2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Metal Casing Replacement: 步骤 2 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement: 步骤 2 中的图像 2,2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Metal Casing Replacement: 步骤 3 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement: 步骤 3 中的图像 2,2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Metal Casing Replacement: 步骤 4 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement: 步骤 4 中的图像 2,2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Metal Casing Replacement: 步骤 5 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement: 步骤 5 中的图像 2,2
    • Identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
  6. Imation Superdisk USB Drive Metal Casing Replacement: 步骤 6 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement: 步骤 6 中的图像 2,2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: 步骤 7 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement, Metal Casing: 步骤 7 中的图像 2,2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Metal Casing Replacement: 步骤 8 中的图像 1,2 Imation Superdisk USB Drive Metal Casing Replacement: 步骤 8 中的图像 2,2
    • Slide disk drive out of metal casing.
结论
Ryan
于02/13/14注册
1 声望
撰写一个指南
团队
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G2
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 8
总计 476
