跳转到主内容
Imation Superdisk USB Drive Disc Drive Casing Replacement
你所需要的
  1. Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: 步骤 1 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: 步骤 1 中的图像 2,2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 2 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 2 中的图像 2,2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 3 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 3 中的图像 2,2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 4 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 4 中的图像 2,2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 5 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 5 中的图像 2,2
    • Identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
  6. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 6 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 6 中的图像 2,2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: 步骤 7 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: 步骤 7 中的图像 2,2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 8 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 8 中的图像 2,2
    • Slide disk drive out of metal casing.
  9. Imation Superdisk USB Drive Disc Drive Casing Replacement, Daughter Board: 步骤 9 中的图像 1,1
    • Flip the disk drive over so the the plug on the daughter board is visible.
  10. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 10 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 10 中的图像 2,2
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  11. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 11 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 11 中的图像 2,2
    • Gently pull on the daughter board until it separates from the device.
  12. Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: 步骤 12 中的图像 1,2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: 步骤 12 中的图像 2,2
    • Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
    • You may have to use the plastic spudger in several spots along the metal casing.
  13. Imation Superdisk USB Drive Disc Drive Casing Replacement: 步骤 13 中的图像 1,1
    • lift the disk drive completely out of the metal casing and set it aside.
结论
另外一个人完成了本指南。
Caitlin Horwatt
于02/11/14注册
137 声望
创作了2篇指南
团队
Ohio State, Team 1-2, Buehl Spring 2014 Ohio State, Team 1-2, Buehl Spring 2014 的会员
OSU-BUEHL-S14S1G2
4 名成员
创作了14篇指南
1指南评论
Does anyone know if the MAC USB version works on modern PCs?
davidpaulpeterson - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 779
