跳转到主内容
Ilco Orion Key Machine deburring wheel replacement
你所需要的
  1. Ilco Orion Key Machine deburring wheel replacement, deburring wheel: 步骤 1 中的图像 1,1
    • As you can see, the deburring wheel on this machine is quite worn down. Time to replace!
  2. Ilco Orion Key Machine deburring wheel replacement: 步骤 2 中的图像 1,1
    • Using an M6 allen wrench (circled in red), remove the old wheel.
    • Use another allen wrench, strategically placed in a hole next to the cutting wheel, to provide torque in the clockwise direction. The size of the wrench does not matter, so long as it fits reasonably within the hole. This is to prevent the whole assembly from turning while loosening the bolt that holds the wheel in place.
  3. Ilco Orion Key Machine deburring wheel replacement: 步骤 3 中的图像 1,1
    • Add washers, as necessary, and replace the wheel.
结论
3等其他人完成本指南。
Jerry Orr
于01/19/12注册
920 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,691
