跳转到主内容
Identifying Combat Machine 16 Carbine and a Raider airsoft guns
你所需要的
  1. Identifying Combat Machine 16 Carbine and a Raider airsoft guns, Identifying Combat Machine 16 Carbine and a Raider airsoft guns: 步骤 1 中的图像 1,3 Identifying Combat Machine 16 Carbine and a Raider airsoft guns, Identifying Combat Machine 16 Carbine and a Raider airsoft guns: 步骤 1 中的图像 2,3 Identifying Combat Machine 16 Carbine and a Raider airsoft guns, Identifying Combat Machine 16 Carbine and a Raider airsoft guns: 步骤 1 中的图像 3,3
    • The biggest difference between a Combat Machine Carbine and a Raider is the wiring. The Carbine is wired to the front, and holds a battery inside the handguard, while the Raider is wired to the rear, and holds a battery in the stock.
    • As you can see in the third picture, you can detach the rear wires from the gearbox after you remove the buffer tube.
  2. Identifying Combat Machine 16 Carbine and a Raider airsoft guns: 步骤 2 中的图像 1,2 Identifying Combat Machine 16 Carbine and a Raider airsoft guns: 步骤 2 中的图像 2,2
    • Another difference is the pistol grip plate. The Raider uses a different style of pistol grip, which also has a different plate from the one found on the Carbine.
    • Instead of using a large, slotted screw for motor height adjustment, this version uses a set screw with a round metal plate on top. It is important that you do not lose this plate when taking apart the gun, and reinstall it in the correct position afterwards.
    • Notice that the plate will have some grease on it. This grease is used to help the plate stick in place, and make it easier to position when installing the pistol grip plate.
终点
2等其他人完成本指南。
101 Tech USA
于08/06/12注册
4,127 声望
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 3,796
