This is a basic replacement guide for replacing a 9-volt battery for an Ibanez Overdrive stompbox pedal. This guide will show you how to access the battery components. No soldering is required to replace the battery.
The guide includes steps for removing the back plate of the stompbox and the tools required for the replacement. The replacement should take no more than 2 - 5 minutes.
Remove the back plate of the stompbox by lifting the backplate upwards.
Next, locate the 9-volt battery, which should be at the bottom of the overdrive stompbox, and carefully pull apart the battery from the battery clip connector.
