跳转到主内容
Ibanez 5 String Bass Model SR405QM Output Jack Replacement
你所需要的
  1. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Battery: 步骤 1 中的图像 1,1
    • Gently place the instrument upside-down on a soft surface.
    • Locate the battery cavity cap and screws.
  2. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #2 head screwdriver to unscrew both screws. Two #1 1mm long screws.
  3. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 3 中的图像 1,2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 3 中的图像 2,2
    • Remove the cap by lifting upwards to reveal the battery.
  4. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 4 中的图像 1,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 4 中的图像 2,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 4 中的图像 3,3
    • Gently lift the battery from the cavity.
    • Detach the battery completely by firmly pulling the fabric connector from the conducting end of the battery.
  5. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Backplate: 步骤 5 中的图像 1,2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Backplate: 步骤 5 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the four screws on the backplate.
  6. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 6 中的图像 1,2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 6 中的图像 2,2
    • Remove the cap by lifting upwards, revealing the circuitry of the instrument.
  7. Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: 步骤 7 中的图像 1,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: 步骤 7 中的图像 2,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement, Output Jack: 步骤 7 中的图像 3,3
    • Lift the green printed circuit board to move some of the wires.
    • Locate the output jack at the base of the cavity.
    • Move wires away from the end of the output jack to expose the three pins.
  8. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 8 中的图像 1,2 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 8 中的图像 2,2
    • Locate the gold nut at the base of the output Jack.
    • Do not remove the nut completely, but leave it about halfway down the output jack. We only want to move the prongs slightly away from all of the wires to allow for easier soldering.
    • Use the wrench to loosen the nut.
  9. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 9 中的图像 1,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 9 中的图像 2,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 9 中的图像 3,3
    • Use a soldering iron to remove the three wires (two black, one white) from the output jack.
    • The soldering iron is extremely hot. Avoid contact with skin, fabric or the body of the instrument. When soldering iron is not in use, rest it on the soldering iron stand.
  10. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 10 中的图像 1,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 10 中的图像 2,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 10 中的图像 3,3
    • Remove the loosened nut completely by rotating it counter-clockwise.
  11. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 11 中的图像 1,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 11 中的图像 2,3 Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 11 中的图像 3,3
    • Flip the bass over.
    • Remove output jack by pushing it gently from the back of the instrument and pulling it out from the front.
    • Insert a new output jack and tighten the nut about halfway.
  12. Ibanez 5 String Bass Model SR405QM Output Jack Replacement: 步骤 12 中的图像 1,1
    • Use the soldering iron to attach the wires on to the new output jack according to the wiring diagram.
    • Securely tighten the nut using the adjustable wrench.
结论
To reassemble your device, follow steps 1-7 in reverse order.
4等其他人完成本指南。
Chris Pittner
于01/11/13注册
220 声望
创作了7篇指南
团队
Cal Poly, Team 5-18, Forte Winter 2013 Cal Poly, Team 5-18, Forte Winter 2013 的会员
CPSU-FORTE-W13S5G18
4 名成员
创作了9篇指南
一条评论
Thanks for the good, clear instructions. Well done, very helpful.
m10, Socorro NM
Clifton - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 43
总计 10,501
