跳转到主内容
IBM/Lenovo Thinkpad T61 Hard Drive Replacement
你所需要的
  1. IBM/Lenovo Thinkpad T61 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  4. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 步骤 4 中的图像 1,2 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  5. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 步骤 5 中的图像 1,2 IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  6. IBM/Lenovo Thinkpad T61 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
结论
To reassemble your device, follow these instructions in reverse order. If your pull tab is broken, you will need to find something to use as a pull tab for the new drive. You can get a long piece of tape, and fold the end and stick the rest to the drive.
7等其他人完成本指南。
Kyle
于04/18/13注册
458 声望
创作了4篇指南
团队
Cal Poly, Team 8-58, Johann Spring 2013 Cal Poly, Team 8-58, Johann Spring 2013 的会员
CPSU-JOHANN-S13S8G58
4 名成员
创作了10篇指南
一条评论
Ibm t61 caddy rail purchase
Afjal Ansari - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 45
总计 6,662
