跳转到主内容
IBM Thinkpad T61 Trackpad Replacement
你所需要的
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: 步骤 1 中的图像 1,1
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: 步骤 2 中的图像 1,1
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: 步骤 3 中的图像 1,2 IBM Thinkpad T61 Trackpad Replacement: 步骤 3 中的图像 2,2
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: 步骤 4 中的图像 1,3 IBM Thinkpad T61 Trackpad Replacement: 步骤 4 中的图像 2,3 IBM Thinkpad T61 Trackpad Replacement: 步骤 4 中的图像 3,3
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: 步骤 5 中的图像 1,1
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: 步骤 6 中的图像 1,1
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: 步骤 7 中的图像 1,2 IBM Thinkpad T61 Trackpad Replacement: 步骤 7 中的图像 2,2
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
结论
Replace the battery and plug in your computer. Test out your new trackpad!
7等其他人完成本指南。
Raymond Lawton
于03/12/14注册
263 声望
撰写一个指南
团队
UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 的会员
UMASSD-VIJAYBHASKAR-S14S6G6
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 2,052
