当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Ensure the laptop has been properly shut down and unplugged.
Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
Use your finger to slide the release tab to the unlocked symbol.
Hold the tab in the unlocked position and push the battery away from the computer to remove it.
Slide the new battery in until it clicks.
Ensure that the release tab is in the locked position.
Using a #0 Phillips screwdriver, remove four 17.0mm screws on the back of the computer.
These screws have a RAM symbol next to them.
Flip back over and open the laptop.
Lift up on the inside front panel just below the edge of the keyboard.
The green rectangles under the front panel are the RAM.
Press out on the two tabs on either side of the ram at the same time.
The RAM will release and pop up at a 25 degree angle.
Pull the RAM away from the housing to remove.
取消:我没有完成这个指南。
15等其他人完成本指南。
与9其他贡献者
于04/18/13注册
458 声望
创作了4篇指南
徽章: 12
+ 9更多徽章
CPSU-JOHANN-S13S8G58
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 60
总计 8,944
