当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use the PH1 bit screwdriver, remove five 17.0mm screws on the back of the computer.
These screws have a keyboard symbol next to them.
Make sure you keep the screws together and do not misplace any of them
Turn the computer over so the keyboard is facing upwards, and open the Thinkpad.
Release the panel by lifting up on the outside edges just below the keyboard.
Gently pull the panel away from the computer.
BE CAREFUL! The panel is still attached by the touchpad's data cable.
Detach the connecter by pulling up on the white tab.
Gently pull up on the connecter to disconnect the keyboard.
The keyboard will no longer be attached and can now be fully removed.
Take the replacement keyboard and push the new connector tab back into place.
Line up keyboard and place back into the position, make sure it is lined up with the back first.
Lower the rest of the keyboard back into place so it lies flat against the computer's shell.
Flip the laptop over so that the side with the screws is facing up.
Put back all the screws, make sure they are in tightly.
The new keyboard is now in securely.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
