跳转到主内容
IBM Thinkpad T60 Touchpad Replacement
你所需要的
  1. IBM Thinkpad T60 Touchpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
    • Use your finger to slide the tab to the right to unlock the battery.
  2. IBM Thinkpad T60 Touchpad Replacement: 步骤 2 中的图像 1,2 IBM Thinkpad T60 Touchpad Replacement: 步骤 2 中的图像 2,2
    • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
    • The battery is now disconnected.
  3. IBM Thinkpad T60 Touchpad Replacement, Palm Rest: 步骤 3 中的图像 1,2 IBM Thinkpad T60 Touchpad Replacement, Palm Rest: 步骤 3 中的图像 2,2
    • Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
    The screws we need to remove all supposedly share the same pictogram imprinted on the bottom case. If this is true why have you circled the rightmost screw in the photo above? The forth pictogram is near the screw below and to the left of the circled screw?
    airshack - 回复
  4. IBM Thinkpad T60 Touchpad Replacement: 步骤 4 中的图像 1,1
    • Turn the computer back over, so the keyboard is facing upwards.
    • Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
  5. IBM Thinkpad T60 Touchpad Replacement: 步骤 5 中的图像 1,2 IBM Thinkpad T60 Touchpad Replacement: 步骤 5 中的图像 2,2
    • Slightly lift the palm rest away from the computer.
    • The touchpad's data cable connects the palm rest to the base unit. BE CAREUL!
    • Detach the connector by pulling upwards on the white tab.
    Putting it back on should be covered too, as it’s really hard to get everything lined up. Would be nice for some tips on that. Took me and other experienced guy 45 minutes to get the thing back on, and have all the screws seat!
    Glenn - 回复
    Where in this guide does it say how much RAM is supported? Am I missing something? Looks like two slots?
    airshack - 回复
  6. IBM Thinkpad T60 Touchpad Replacement, Touchpad: 步骤 6 中的图像 1,1
    • Turn the palm rest over to access the back of the touch pad.
  7. IBM Thinkpad T60 Touchpad Replacement: 步骤 7 中的图像 1,1
    • Using your fingers, remove the plastic film that covers the two connectors to the touchpad.
  8. IBM Thinkpad T60 Touchpad Replacement: 步骤 8 中的图像 1,3 IBM Thinkpad T60 Touchpad Replacement: 步骤 8 中的图像 2,3 IBM Thinkpad T60 Touchpad Replacement: 步骤 8 中的图像 3,3
    • Identify the connector with the black cables.
    • In order to disengage the connector, use tweezers to pull out on the two grey tabs
    • Once the grey tabs have been disengaged, use tweezers to pull on the black cables and the connector will detach from the port.
  9. IBM Thinkpad T60 Touchpad Replacement: 步骤 9 中的图像 1,2 IBM Thinkpad T60 Touchpad Replacement: 步骤 9 中的图像 2,2
    • Identify the connector with the orange cables.
    • In order to disengage the connector use tweezers to pull the orange cable outward.
  10. IBM Thinkpad T60 Touchpad Replacement: 步骤 10 中的图像 1,2 IBM Thinkpad T60 Touchpad Replacement: 步骤 10 中的图像 2,2
    • Use a #0 Phillips screwdriver to unscrew the four 3.4 mm screws circled in red.
  11. IBM Thinkpad T60 Touchpad Replacement: 步骤 11 中的图像 1,1
    • Using your fingers, remove the metal framing surrounding the touch pad by pulling upwards on each of the four corners.
  12. IBM Thinkpad T60 Touchpad Replacement: 步骤 12 中的图像 1,1
    • Remove the touch pad by lifting it out of the palm rest with your fingers.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 7-9, Maness Winter 2013 Cal Poly, Team 7-9, Maness Winter 2013 的会员
CPSU-MANESS-W13S7G9
4 名成员
创作了16篇指南
2条评论
I bought mine used on eBay. and upgraded the HDD and RAM and it is working perfectly. But I recently noticed that the palm rest is not perfectly seated at the front edge and is raised by roughly 2mm. (⅛in.) I have tried refitting the palm rest, but it hasn’t made any different. It is possible that it was like that before I fitted the RAM and I just hadn’t notice, so it could be the result of an earlier intervention. The machine still works OK and the lid closes, so it isn’t a big deal, but it is a bit annoying that such a well engineered device doesn’t go back together exactly as it should. Any suggestions?
Mike Kearney - 回复
Sort of solved it . . . . . Get the left hand side located first and jiggle it about a bit and the palm rest will fit back neatly. But it isn’t immediately obvious how you shouls go about this.
Mike Kearney - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 3,650
