当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
Use your finger to slide the tab to the right to unlock the battery.
Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
The battery is now disconnected.
Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
Turn the computer back over, so the keyboard is facing upwards.
Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
Slightly lift the palm rest away from the computer.
The touchpad's data cable connects the palm rest to the base unit. BE CAREUL!
Detach the connector by pulling upwards on the white tab.
Press out the two tabs on either side of the card at the same time.
The memory card will slide upwards at a 20 degree angle.
Remove the memory card from the slot by pulling perpendicular to the slot.
取消:我没有完成这个指南。
14等其他人完成本指南。
与10其他贡献者
于01/11/13注册
515 声望
创作了5篇指南
徽章: 13
+ 10更多徽章
CPSU-MANESS-W13S7G9
4 名成员
创作了16篇指南
God daamm im d
Keyten Martodikromo - 2016年5月30日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 51
总计 14,805
