简介
Always power down the computer before attempting any installation/removal of any hardware components. Be sure to remove the AC adapter and all cables from the computer. If the computer has been on, wait several minutes before beginning the procedure to ensure all parts have cooled down.
你所需要的
Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
Use your finger to slide the tab to the right to unlock the battery.
Using a #0 Phillips screwdriver, remove the four 17.0 mm screws.
Slightly lift the palm rest away from the computer.
Detach the connector by pulling upwards on the white tab.
5等其他人完成本指南。
一条评论
Needs a tutorial on how to install it. I can’t get the palmrest on correctly, I can still lift up on the palmrest and the laptop doesn’t latch properly.
