当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
The battery is now disconnected.
Turn the computer back over, so the keyboard is facing upwards.
Open the display to access the palm rest. Apply pressure to the sides of the palm rest so that it bends upwards in the middle. Gently lift away from the computer.
Slightly lift the palm rest away from the computer.
The touchpad's data cable connects the palm rest to the base unit. BE CAREUL!
Detach the connector by pulling upwards on the white tab.
Turn the Thinkpad over so you can see the bottom.
Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
First, flip the laptop back over. Next, use your fingers to pry the keyboard upwards slightly.
Lift the keyboard until you are able to see the wire connection
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
