当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the Thinkpad over so you can see the back.
Locate this screw in the bottom left-hand corner.
Using a #0 Phillips screwdriver, remove the 17.0 mm screw.
Carefully remove the plastic piece covering the hard drive port by pulling perpendicular to the side of the laptop.
Use a small screwdriver to locate the black ribbon.
With the screwdriver, pull the black tab out of the slot.
Pull gently on the black ribbon and the metal tray carrying the hard drive will slide out.
Remove the black plastic coverings on either side of the hard drive.
There is not a hard drive in this example, but the process is the same regardless.
取消:我没有完成这个指南。
7等其他人完成本指南。
与10其他贡献者
于01/11/13注册
515 声望
创作了5篇指南
徽章: 13
+ 10更多徽章
CPSU-MANESS-W13S7G9
4 名成员
创作了16篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 50
总计 10,541
