跳转到主内容
IBM ThinkPad X41 Keyboard Replacement
你所需要的
  1. IBM ThinkPad X41 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 IBM ThinkPad X41 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • Slide outward to unlock and lift battery up to remove.
    • Remove battery before keyboard to avoid damage to battery.
  2. IBM ThinkPad X41 Keyboard Replacement: 步骤 2 中的图像 1,1
    • With a Phillips PH000 to remove all six 6 mm screws identified for the keyboard as shown.
  3. IBM ThinkPad X41 Keyboard Replacement: 步骤 3 中的图像 1,3 IBM ThinkPad X41 Keyboard Replacement: 步骤 3 中的图像 2,3 IBM ThinkPad X41 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Flip the laptop over once more returning it to its upright position and open laptop .
  4. IBM ThinkPad X41 Keyboard Replacement: 步骤 4 中的图像 1,2 IBM ThinkPad X41 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Using your left hand, place thumb on the upper part of the keyboard and place your other thumb on the bottom part of the keyboard.
    • Push firmly upward with both thumbs. This will detach keyboard from base.
    • Be cautious when lifting as there is an orange connection cable still attached to the bottom side.
  5. IBM ThinkPad X41 Keyboard Replacement: 步骤 5 中的图像 1,2 IBM ThinkPad X41 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Detach the connection to the motherboard by first sliding it towards you, then pulling upward away from your body.
    • This step's directions are based on the angle shown .
  6. IBM ThinkPad X41 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Lift the entire keyboard off the laptop.
结论
另外一个人完成了本指南。
Lisbeth Cisneros
于09/12/16注册
131 声望
撰写一个指南
团队
CSU Fullerton, Team 2-4, Bruce Fall 2016 CSU Fullerton, Team 2-4, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 14
总计 897
